AVB Input Streams
The AVB streams received by the 12Mic are referred to as "input streams". For these streams, the device acts as an AVB Listener.
To establish a connection between a talker and a listener, an ATDECC Controller is required. The 12Mic does not include an ATDECC Controller.
AVB input streams are monitored as follows:
Description Indicator Possible solution
Disabled
grey
Create connection with ATDECC controller
Streaming/Receiving
green
No Data
red
Verify proper talker configuration
SR Mismatch
red
Verify that the sample rates of talker and listener are identical
Waiting
yellow …​
Waiting for talker to be ready
Talker Fail
red
No Bandwidth
red
Use faster network speed (1 GBit/s instead of 100 MBit/s)
Domain Boundary
red
Reconnect all devices and reboot switch, ensure only AVB switches are used
Internal Error
red
Reboot device
Change AVB Input Stream Size
Each of the eight AVB streams can have a size of 1-8, 12 or 16 channels in AM824 and AAF stream formats.
To change the amount of channels and format of incoming AVB streams:
  1. Open the AVB tab in the INPUT section.
  2. Use the first button and encoder to select an incoming stream.
    w1A 230 2T 1
  3. Use the second button and encoder to change the stream size and format.
To change the amount of channels of the incoming AVB streams using the web remote:
  1. Connect the device by USB or network cable and open the Remote Control Overview.
  2. Open an AVB port in the routing area and use the up and down arrows wAL co 1 to adjust the stream size.
  3. Use the stream format dropdown wAL co 2 to select the format to be used.
    wAL 230 2T 2
  4. Click OK wAL co 3.
Changing a stream size briefly interrupts all incoming AVB streams.
Incoming streams can contain less than the specified amount of channels.
