Routing Signals to the Outputs
Each output channel of the AVB Tool can receive any input signal. If preset 1 has not been modified, it contains a routing of all analog inputs to all digital outputs. However, this can be adjusted and changed easily. The factory default preset does not contain any routing.
| A routing immediately activates input monitoring for a corresponding digital input and raises a warning in the input state if the source signal is not available or out of sync. |
The following example shows the procedure to route to MADI Coaxial output channels. Other outputs follow the same procedure.
Open the routing tab of the MADI Coaxial output in the OUTPUT section (see Controlling the device).
Activate the routing destination and choose an output channel with the encoder (steps 1 and 2).
Activate the routing source and choose an input channel with the encoder (steps 3 and 4).
Navigate to the corresponding output channel (1, 2).
Double click on "Increment routing". The routing source will be changed to "not routed".
(optional) Hold "increment routing" while turning the encoder to remove routings to the following output channels.
Navigate to the first output channel (1, 2) and create a routing as described above.
Hold "increment routing" while turning the encoder clockwise to increment input channel and output channel at the same time.
Enter the Routing mode by pressing the corresponding icon in the title bar.
Click the MADI coaxial or MADI optical output port.
Select individual or consecutive channels by clicking or dragging. The channels are highlighted in blue and an arrow handler is revealed.
If the input ports are closed, drag the handle onto an input port, it opens automatically.
Drag the handle onto the source channel strips to select a range of channels as signal source.
