Analog Outputs
Phones Out
The front TRS connector can be used for phones or as a balanced mono output. Any incoming signal can be routed to the phones output. Analog input signals can be temporarily routed to the phones output while the original routing remains saved. A button on the standby screen gives access to all features of the output. |
| The analog output level meters show the routed input signal relative to 0 dBFS (pre gain) in grey color in the background, and additionally the calculated output level post gain in green color in the foreground. |
Adjusting the Headphone Volume
The volume of the unbalanced phone outputs can be adjusted separately or as a stereo pair.
While on the main screen, rotate the encoder. The current volume will be shown below the encoder on the screen.
Open the headphone configuration by clicking the phones icon on the main screen.
Open the additional settings by pressing the encoder.
Press the "Stereo" button to separate the left and right channel. Each channel now has its own volume control which can be accessed by toggling the following button on the phones screen:
Follow the same procedure to join the two channels as a Stereo channel.
Open the corresponding output channel strip.
Use the encoder to adjust the gain in the 'PHONES' channel strip.
| Press the Shift key while dragging the knob for finer adjustments. |
| Clicking twice on the encoder knob opens a text field that can be used to input a value using the keyboard. |
Press the Button labeled "Stereo". The button turns grey and a second channel strip opens with its own gain control.
Press the "Stereo" button again to create a stereo channel.
| Any previously created gain offset between left and right channel will be ignored when joining the channels to a stereo group. |
Muting the Phones Output
While on the main screen, press the headphone button. The phones settings open.
Press the mute button. It turns red to symbolize that the phones are muted.
Press the mute button in the Phones output channel.
Using Phones Out as a Balanced Line Output
The headphone output can operate as a mono balanced line level output. This may for example be useful when an active talkback speaker with symmetrical input is connected to the 12Mic.
On the main screen, press the PHONES button to access phones output settings.
Press the encoder to open additional settings .
Press the BAL button to switch the channel to balanced out.
Open the phones output channel.
Press the BAL button to switch the channel to balanced out. The channel that was routed to the left phones output will now be applied to both tip and ring of a TRS connector, the phase being inverted on the ring.
Line Level Outputs
The rear analog TRS connectors can be configured as individual channels or a stereo pair and their level adjusted to +4 dBu or +19 dBu. Any incoming signal can be routed to the analog outputs. To access these channels from the standby screen, open the phones settings first and then use the '3|4' button to open the line outputs. |
Changing Analog Output Volume
The level of the balanced line level outputs can be adjusted separately or as a stereo group.
Press the '3|4' selection button to access output channel 3 and 4.
Adjust the volume using the encoder.
Open output channel 3|4 as above.
Press the encoder to open additional settings.
Click the "Stereo" button to separate the channels.
Ensure that the Stereo button is active (yellow).
Use the volume knob to adjust both channels at once.
Press the Stereo button to separate the left and right channel.
Use both volume knobs for gain control.
