Sample Rates Overview
The AVB Tool supports the following sample rates:
Supported sample rates
Single speed
44.1 kHz, 48 kHz
Double speed
88.2 kHz, 96 kHz
Quad speed
176.4 kHz, 192 kHz
If the device is clock reference ("leader"/"master"), these rates always correspond to the actual sample rate used.
Following an External Clock Reference
When the device is synchronized to an external clock reference ("follower"/"slave"), certain deviations are automatically accepted to avoid interruption of the outgoing audio signal when the sample rate changes. This is called Intelligent Clock Control (ICC). It also handles deriving a sample rate of double or quad speed based on an incoming rate.
Input
Clock at input
Selected Sample Rate
Resulting Sample Rate
MADI
44.1
44.1
44.1
MADI
44.1
48
44.1 with warning
MADI
44.1
88.2
88.2
MADI
44.1
96
88.2 with warning
MADI
44.1
176.4
176.4
MADI
44.1
192
176.4 with warning
MADI
48
44.1
48 with warning
MADI
48
48
48
MADI
48
88.2
96 with warning
MADI
48
96
96
MADI
48
176.4
192 with warning
MADI
48
192
192
MADI 96k
88.2
44.1
warning (no sync)
MADI 96k
88.2
48
warning (no sync)
MADI 96k
88.2
88.2
88.2
MADI 96k
88.2
96
88.2 with warning
MADI 96k
88.2
176.4
warning (no sync)
MADI 96k
88.2
192
warning (no sync)
MADI 96k
96
44.1
warning (no sync)
MADI 96k
96
48
warning (no sync)
MADI 96k
96
88.2
96 with warning
MADI 96k
96
96
96
MADI 96k
96
176.4
warning (no sync)
MADI 96k
96
192
warning (no sync)
Word Clock
44.1
44.1
44.1
Word Clock
44.1
48
44.1 (with warning)
Word Clock
44.1, 88.2
88.2
88.2
Word Clock
44.1, 88.2
96
88.2 with warning
Word Clock
44.1, 88.2, 176.4
176.4
176.4
Word Clock
44.1, 88.2, 176.4
192
176.4 with warning
Word Clock
48
44.1
48 with warning
Word Clock
48
48
48
Word Clock
48, 96
88.2
96 with warning
Word Clock
48, 96
96
96
Word Clock
48, 96, 192
176.4
192 with warning
Word Clock
48, 96, 192
192
192
There is no ICC mechanism necessary for AVB; the device will always use the exact clock from the corresponding AVB stream.
It is not recommended to synchronize devices with a higher sample rate than the current sample rate, because two devices could choose different edges of the incoming clock signal.
ICC does not affect outgoing AVB streams. Outgoing AVB streams will always correspond to the sample rate set in the CLOCK section. If the reference clock changes its frequency, outgoing AVB streams will be interrupted.
Number of Channels
The supported number of channels per port or stream at different sample rates is shown in the following table.
Supported number of audio channels per stream/port and direction at different sample rates
44.1 kHz
48 kHz
88.2 kHz
96 kHz
176.4 kHz
192 kHz
MADI 56 Ch
56
56
28
28
14
14
MADI 64 Ch
64
64
32
32
16
16
MADI 56 Ch + 96k
28
28
MADI 64 Ch + 96k
32
32
AVB 1-8 Ch stream
1-8
1-8
1-8
1-8
1-8
1-8
AVB 12 Ch stream
12
12
12
12
AVB 16 Ch stream
16
16
Since there are two independent MADI ports, the total supported number of channels can be multiplied by two. Since there are eight independent AVB streams, the total supported number of channels can be multiplied by eight. The analog channel count remains identical at all sample rates.
Selecting a Sample Rate
To configure the sample rate on the device:
  1. Enter the CLOCK section (see Controlling the device).
    Clock Rate
  2. Use the button next to the current sample rate. Two blue arrows will appear to indicate that the encoder can now be used to change the rate.
  3. Rotate the encoder until the preferred sample rate is shown.
  4. Push the encoder again to activate the setting.
wAL 430 2T 2
To configure the device sample rate on the web remote:
  1. In the clock panel, click the first icon containing the current sampling rate.
  2. Select the new sampling rate.
Effects of Sample Rate Changes on Existing Routing
The AVB Tool saves one routing table per preset, regardless of sample rate. A change of sample rate or MADI frame mode can reduce the number of input and output channels available for routing. This does not alter the routing table. Any existing routing is hidden until another change of sample rate re-enables the channels.
Example:
A routing is created at 96 kHz with 32 channels, sending the MADI coaxial Input 1-32 to optical MADI Output 1-32. If the sample rate is now changed to 176.4 kHz and the 56 Ch frame is activated, only the first 14 channels of MADI coaxial input are routed to the optical output. Switching the sample rate to 44.1 or 48 kHz will reveal the previous routing for 32 channels.
