Presets
Any change in the device configuration is persistent. After a power loss, the device will revert back to its last state. Additionally, the M-1610 Pro can save fifteen states in presets numbered 1-15. After a preset is loaded, any change in the configuration will result in an unsaved changes state.
Representation of an unsaved preset on the device. |
| The internal preset storage is not affected when the device firmware is updated to a newer firmware version. Moreover, recalling the factory default preset does not delete any other saved preset. |
Settings that are not saved in a Preset
Auto-lock
Lock code
Remote control
Static IP/DHCP configuration
MIDI Remote Control ID
Saving Presets
Up to 15 presets can be saved in the internal storage of the M-1610 Pro.
Open the preset tab in the STATE section. The cursor will highlight a preset number.
Push and rotate the encoder to choose a preset number.
Push Save to save the preset.
Open the web remote and locate the preset tab.
Status Indicator and tab
Current preset and state
Selected preset
Save preset
Click on a preset name in the left column
to select a preset. -
Press the Save button
Loading Presets
Up to 15 custom presets can be loaded from the internal storage of the M-1610 Pro.
| Loading a preset cannot be undone. Ensure that any important configuration has been saved to another preset before proceeding. |
| The device name is part of the preset. When a preset is loaded, the device name is changed to the value stored in the preset. |
Open the preset tab in the STATE section (see: Use of the Display and Encoder).
Move the cursor to the current preset number and push the encoder.
Rotate the encoder to choose a preset, and confirm by pushing the encoder.
Select Load to load the preset.
Locate the preset tab
Load (or Revert) button
Use the drop-down menu
Press the Load Button
Loading Factory Default Settings
The factory default settings are saved internally as Factory Preset and cannot be overwritten.
To load the factory defaults, load the 16th preset labelled Factory Preset.
| Loading the factory defaults does not delete any saved presets. It also does not affect the lock settings in the STATE section. |
