Headphone Outputs
The M-1620 Pro features two headphone outputs, 1/4" (6.3mm) TRS, on the front panel. They can also function as a dual mono unbalanced outputs with individual routing and gain control and as a mono balanced line level outputs. Any digital or analog input signal can be monitored.
| Do not use TS (Mono, unbalanced) connectors at this output. |
| When using "balanced" mode, the output signal increases by 6.02 dB. |
