ADAT Inputs and Outputs
Four ADAT inputs and four outputs can be found at the rear of the device.
Each port can send up to eight audio channels. At double and quad speed, the maximum of channels per port is reduced to four and two respectively.
| Even when no signal is routed, the outputs send a valid ADAT signal. This can be used to synchronize other devices. |
