Firmware Revision History
Firmware 3.0.7 (APR/1/2025) m1620_3.0.7_v182_20250401.swu
  • Fix: Under rare circumstances, booting the device would take unusually long with 3.0.6
Firmware 3.0.6 (MAR/26/2025)
  • Avnu™ MILAN® Certified
  • Feature: (MIDI) Improved response to parameter change request messages
  • Fix: ADAT level meters not working at sampling rates ≥ 88.2 kHz
  • Fix: Unrouted channels would receive signals from ADAT 3 Ch. 8
  • Feature: Faster change of sampling rate
Firmware 3.0.3
  • Initial release
Changing sampling rates will change the sampling rate of the device but keep existing AVB streams running with wrong stream format and audio payload due to MILAN requirements. It is highly recommended to use an ATDECC controller (Milan Manager® or Hive) to manage routing and sampling rate changes in MILAN environments.
