AVB Input Streams
The AVB streams received by the M-32 AD Pro are referred to as "input streams". For these streams, the device acts as an AVB Listener.
To establish a connection between a talker and a listener, an ATDECC Controller is required. The M-32 AD Pro does not include an ATDECC Controller.
AVB input streams are monitored as follows:
| Description | Indicator | Possible solution |
Disabled |
grey |
Create connection with ATDECC controller |
Streaming/Receiving |
green |
No Data |
red |
Verify proper talker configuration |
SR Mismatch |
red |
Verify that the sample rates of talker and listener are identical |
Waiting |
yellow … |
Waiting for talker to be ready |
Talker Fail |
red |
No Bandwidth |
red |
Use faster network speed (1 GBit/s instead of 100 MBit/s) |
Domain Boundary |
red |
Reconnect all devices and reboot switch, ensure only AVB switches are used |
Internal Error |
red |
Reboot device |
Change AVB Input Stream Size
Each of the eight AVB streams can have a size of 1-8, 12 or 16 channels in AM824 and AAF stream formats.
Open the AVB tab in the INPUT section.
Move the cursor to highlight the corresponding AVB stream size and press the encoder.
Rotate the encoder to configure a new stream size and format, then confirm by pressing the encoder again.
Connect the device by USB or network cable and open the Remote Control Overview.
Open an AVB port in the routing area and use the up and down arrows
to adjust the stream size. -
Use the stream format dropdown
to select the format to be used.
Click OK
| Changing a stream size briefly interrupts all incoming AVB streams. |
| Incoming streams can contain less than the specified amount of channels. |
