RME Manuals
RME M-32 AD Pro II
    • Safety Precautions
    • Introduction
      • Firmware Update
      • Use of the Display and Encoder
      • Status Indicator Color Chart
    • Hardware
      • Hardware Specifications
      • Package Contents
      • Power On
      • Standby Switch
      • Ring Illumination
      • Channel Labels with Integrated Metering
      • Meter Backlight Color and Intensity Reference
      • Replacing the Channel Labels
      • Control Section
      • Power Supplies
      • Analog Line Input Connectors
      • AD Converter Specifications
      • Analog Line Levels
      • MADI Coaxial and SFP
      • Network Connection
      • MIDI Connector
      • Word Clock
      • USB 2.0 Type B Jack
      • Mounting the Rack Adapter Brackets
    • Accessories
    • MILAN® AVB Connectivity
      • Identifying a Device Remotely
      • Changing the Device Name
      • AVB Stream Size and Format
      • AVB Network Latency
    • Quick Start (MADI)
    • Warranty and Support
      • Support Contacts
    • STATE Section
      • Power State
      • Presets
      • Device Lock
      • Front Panel Illumination
      • Remote Control Overview
      • Monitor Fan Speed and Temperature
      • Anti-Aliasing Filter
      • Device Information
    • INPUT Section
      • Analog Inputs
      • MADI Inputs
      • AVB Input Streams
    • OUTPUT Section
      • Routing Signals to the Outputs
      • MADI Outputs
      • AVB Output Streams
    • CLOCK Section
      • Clock Status
      • Clock Reference
      • Sample Rates Overview
      • Set Word Clock Output to Single Speed
    • Annex
      • MIDI Implementation Chart
      • Glossary
    • Firmware Revision History
      • Regulatory Compliance
  • RME M-32 AD Pro II
  • Hardware
Hardware
wAD2 020 1C 1
wAL co 1
Standby Switch
wAL co 2
wAL co 3
Control Section
wAL co 4
Word Clock
wAL co 5
MIDI Connector
wAL co 6
wAL co 7
wAL co 8
Network Connection
wAL co 9
wAL co 10
USB 2.0 Type B Jack
wAL co 11
Power Supplies
Was this topic helpful?
Thank you!
Thank you for letting us know.
Please tell us what you were looking for:
Your E-Mail (in case you would like us to contact you):
Status Indicator Color Chart Hardware Specifications
©2025 RME / m2lab Ltd.
