Power On
The M-32 AD Pro II has a power off switch at the rear and a standby switch at the front.
Perform the following steps to power on the M-32 AD Pro II:
Ensure either or both power inlets are properly connected to a power source.
Toggle the mains switch at the back of the device to position I (down). The power indicator will light up in red (Standby) or white (On). This depends on the state of the device before the rear switch was toggled or the power cord removed.
If the device is in standby mode, push the standby switch to boot the device.
| The M-32 AD Pro II features a dark mode which deactivates some or all lights of the front panel. This can be used to let the device appear powered off when it is in fact powered on. A short push on the standby switch or the the encoder deactivates this mode temporarily. |
