MILAN® AVB Connectivity
This device implements MILAN®, which is an interoperability standard for time aware ethernet networks based on AVB. In comparison to legacy ethernet, an AVB network offers deterministic audio streaming with fixed, precise latency alongside other traffic - out of the box. A separation of audio or control traffic from any other type of network traffic is not necessary.
Network Control
The M-32 AD Pro II is a MILAN-compliant endpoint device that can be configured with the IEEE Standard for Device Discovery, Connection Management, and Control Protocol for IEEE 1722™ Based Devices, in short: ATDECC.
This device does not provide an ATDECC controller for other devices on a network. To establish an AVB connection between devices, a separate controller is required.
There are several ATDECC controllers available for download from different manufacturers that support the commands required to
  • identify the device,
  • adjust its sampling rate and clock source, and
  • create connections to or from it.
Some additional configuration options of the M-32 AD Pro II may not be implemented in generic ATDECC controllers. These can be inspected and controlled on the device itself, with the web remote, or using a JSON API.
A recommended controller is the MILAN Manager, which can be downloaded from the following link:
Audio Streaming
The M-32 AD Pro II has nine outgoing and nine incoming stream ports. Eight streams can be configured to contain 1-8, 12 (at up to 96 kHz) or 16 (at up to 48 kHz) audio channels in AAF or AM824 format. The ninth stream supports only the clock reference format (CRF) and is exclusively used for clocking, not for audio streaming. In order to establish a connection (stream) between two AVB devices, the following conditions must be fulfilled:
  1. There must be a physical connection between the devices.
  2. All switches between the devices must be certified AVB switches (or compatible).
  3. An ATDECC Controller is required to find the devices and to connect them.
  4. Talker and listener must be configured to use the stream format and channel count.
A stream between two AVB devices is deterministic, has a fixed latency, and reserved bandwidth.
