Network Connection
On the rear of the M-32 DA Pro II, two RJ45 connectors labeled NET (PRI) and NET (SEC) provide ethernet connectivity. The supported link speed is 1 Gb/s for AVB.
w322 021 10C 1
A green LED (left) signals network traffic (blinking). A yellow LED (right) signals a successful link.
Both straight and crossover cables can be used (Auto MDI-X). Cable lengths of up to 100m are supported when using Cat 5e or higher classification.
The network ports are used to send and receive:
  • up to eight AVB audio streams when connected to AVB switches and endpoints,
  • one CRF clock stream,
  • remote status/control with ATDECC, and
  • remote status/control with HTTP over IP routed networks.
The current link state is also shown on the display of the M-32 DA Pro II. Two network port icons in the menu reveal the following states:
Icon Description
Link Icons
wAL 021 10C 3
No link - cable not connected
wAL 021 10C 4
Negotiating link with other endpoint
wAL 021 10C 5
Link with speed of 100 MBit/s (not supported for audio streams)
wAL 021 10C 6
Successful link with speed of 1 GBit/s
