Introduction
The M-32 DA Pro II-D is a versatile multichannel format converter with exceptional audio quality across each of its channels. State-of-the art components from audiophile grade converters have been carefully aligned to fit into a compact, 1 HU 19" rack device.
The device was designed to use the entire front for visual feedback on its state and configuration. A display with encoder allows to perform all configurations directly at the device. Thirty-two custom-inscribable labeling fields with backlight in shades of green, yellow, and red indicate the current signal level.
Each analog channel can be individually adjusted to three different sensitivities that are perfectly matched to the converter’s range. While this is usually implemented with digital 'trims', the M-32 DA Pro II-D does the adjustment in the analog domain, ensuring that the converter’s signal to noise ratio is not reduced when adapting to common line levels.
By integrating Audinate’s Dante® IP Core on a custom built RME FPGA platform, RME is not only delivering a highly flexible solution but also gets one step closer to achieving a truly universal Audio Networking experience. Any signal reaching the M-32 DA Pro II-D can be routed and streamed over IP networks, including MADI signals!
The coaxial MADI port and a slot for a second, independent or redundant optical MADI port (SFP module) can be used for daisy chaining, merging and converting MADI signals with lowest latencies.
The following manual provides a detailed explanation of features and their proper use. Please read the safety instructions carefully.
Although the contents of this manual have been thoroughly checked for errors, RME can not guarantee that it is correct throughout. RME does not accept responsibility for any misleading or incorrect information within this guide. RME reserves the right to change specifications at any time without notice.
