Dante Input
Connections to the M-32 DA Pro II-D are created and inspected using the Dante® Controller. It can be downloaded as described here: Dante Connectivity.
On the web remote, the Dante input is shown as an expandable tile with all incoming audio levels:
Routes from any incoming Dante channel can be internally connected to any output channel. The current routings are indicated as lines between inputs and outputs.
The signals that are received via Dante are shown within the input section:
It is not possible to see where the signals are routed from the input section on the device. Routings are created and inspected within the output ports.
